Ethernet OAM received an unknown or unrecognized PDU. This should never occur, but if it does, we simply drop the PDU. Receiving a large number of these messages is indicative of a problem at the lower layers.
Check that the peer is running a compatible version of Ethernet OAM.
Warning
Unknown PDU received on port %port%. %typeInfo%
| Name | Type |
| port | SlotPort |
| typeInfo | uInt |
